Create a report of all confluence space with the below details using scriptrunner
I just wrote one and seems like it does the job. You can always customise as per your need.
SELECT t1.spacename, t1.spacekey, t1.creationdate, t1."Total Attachments Size", t1."Total Number of Attachments", t2."Pages Size", t1."Last Modified Date"
FROM (
SELECT s.spacekey, s.creationdate, (ROUND(SUM(longval)/1048576,2) || 'MB' )
AS "Total Attachments Size", COUNT(*)
AS "Total Number of Attachments", s.spacename,
MAX(c.lastmoddate) AS "Last Modified Date"
FROM contentproperties cp
JOIN content c
ON cp.contentid = c.contentid
JOIN spaces s
ON s.spaceid = c.spaceid
WHERE propertyname = 'FILESIZE'
GROUP BY s.spacekey, s.spacename, s.creationdate
) t1
JOIN (
SELECT s.spacekey, (ROUND(SUM(char_length(bc.body))/1048576,2) || 'MB')
AS "Pages Size"
FROM content c
JOIN bodycontent bc
ON c.contentid = bc.contentid
JOIN spaces s
GROUP BY s.spacekey
) t2
ON t1.spacekey = t2.spacekey;
Srinath T
Thanks Srinath, but seems like it is not fetching the result and throwing up error. @Srinatha Tondihal
Is it possible we can get the count of active users tagged to a space (extranet users) along with this data, then it would be fine. And also the query you have posted, just wanted to tell, that it doesnt retreive the spaces which has 0 attachment size. Can that be also setup?
@Mohammed Siyad which database you are using? Can you check with your admin team and ask them to run this query against confluence DB?
Srinath T
I just went through script runner docs and I think below doc has the info you are looking for.
I hope the info helps. have a good day
Srinath T
Thanks for the reply, can you clarify couple of questions too.
Appreciate your help in here!!
Hi @Mohammed Siyad ,
I have tested the query in my test environment and works fine for me. Not sure why it did not work for you.
Since you have other requirements now. You might want to go for some third party plugin's which will fetch the details for you. Like Example:
Srinath T
Welcome to Atlassian community.
I am not sure about script runner as i have never used it. But I think we can get the info from the dabase by writing a SQL query. If you are interested then i can write one for you. It should be achieve-able.
Have a good day!
Srinath T
Probably SQL query would work fine, as I can get the data all fetched out by puting SQL in script and return as a report.
Hi @Srinatha Tondihal , I would like to get the SQL query to get the list of all confluence spaces with the following details:
Also, if you could point me to where I can run this SQL query would also be greatly appreciated.
Sam
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
