Using JIRA - Data Center Version.
I have a simple XML file with below three headers along with its corresponding content
User Story Name :XXXXXX
Description : YYYYYYYY
Acceptance Criteria : ZZZZZZZZ
Is it possible to import this .xml file onto a Confluence Page using the REST API Call.
Dear @Santanu Roy ,
sure it is. I assume that you would like to display the 3 headers like panels or other structured elements on a page.
All you need is the documentation to the REST API and a browser extension to test your rest calls.
The way how to do:
You will find some samples here. I recommend to use a script language like Python or PHP to write some simple code to repeat the REST calls in an easy way without the browser extension.
So long
Thomas
Note: If you just want to upload the XML as an attachment to an existing page, serach for this at the samples.
Dear @Santanu Roy ,
was my answer useful? Then I would be happy when you click on the "green accept answer" button.
So long
Thomas
See inside
