Sign up Log in
Is there a way to not alphabetize the page properties report table?
Stephanie Hinnerichs
December 10, 2020
I created a page in confluence and I added the page properties report to the parent page.  I create child pages and added the page properties macro on it & a table to each child page.   When the results appear on the parent page the table results are in alphabetical order.
Is there a way we can change it so the table on the parent page shows the same order as the table on the sub page?
Current View:
Order we would like them in:
Katerina Kovriga _Stiltsoft_
December 10, 2020
Hi @Stephanie Hinnerichs ,
Check if the Table Filter and Charts for Confluence app is installed for your instance - you may use its Table Transformer macro.
Wrap your Page Properties Report into the Table Transformer macro and check the following community questions:
Hope this helps.
Geordie Lindsay-Russell
February 14, 2022
Not clean but there is a solution... Numeric prefix e.g. 1) Initiative Summary 2) Overall Status
Upcoming Confluence Events
