I'm having some trouble with a Ubuntu 18.0.4 LTS local VM. It was working perfectly fine 1-2 days ago and I was able to access confluence perfectly fine. Usually the VM sits at 1-2%/low ram/low disk usage since I'm really the only one that uses it. It weirdly spikes to 100% CPU usage and just completely stops working. I've tried several times to start the service after the reboot since it used auto start. So, whenever I'd run /etc/init.d/confluence start it would run okay for a little then after 15 minutes it would just freeze and then give me an err_connection through the web browser, unable to ping, and can't browse the vm through VMware remote until I restart it. Now confluence won't start.
Here's a picture of my Top command
Here's my last "admin" action before things stopped working the next day
Hi!
please, double check the GC log.
unfortunately, I found that request too late.
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
