Has anyone ran in to the problem with comments not working correctly with IE 10 and Confluence?
I have a machine in the office that's recently been updated to IE 10 and can now no longer reply to comments. When you try to replay it sits with a grey screen in the comments box and never continues.
The odd thing is if you actually create a new comment it allows you.
Thanks.
Hi Steven, it looks like IE10 it's not fully supporte on Confluence yet. I found this issue:
Altought, in this page it says yes:
https://confluence.atlassian.com/display/DOC/Supported+Platforms
Internet Explorer 10 in 'desktop' mode does support the drag-and-drop functionality.
The 'modern' mode of Internet Explorer 10 does not support drag-and-drop.
Could it be like the problem with the Drag and Drop?
Thanks. We tried compatibility mode but it was still the same results.
The drag and drop issue is separate and we use Firefox for a workaround.
Read more 📚Online forums and learning are now in one easy-to-use experience.
