Issues with Images Disappearing. Restarting docker container sometimes fixes the issue.
Craig Day
I'm currently trying to debug an issue that I'm having in confluence. We're also running Scroll Viewport - not sure if this is causing some weird issues. Running Atlassian Confluence Server 7.5.2. How do I find where these images are stored in confluence? I see that part of the path is the following:
/files/latest/24938212/28807173/1/1670534498368/AM65-S4-SD_00001000.png
I'm currently getting the following error when viewing the images that are broken:
Cause
java.lang.NullPointerException
    at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:2314)
Stack Trace:[hide]
	at org.apache.commons.io.IOUtils.copy(IOUtils.java:2270)
	at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:2291)
	at org.apache.commons.io.IOUtils.copy(IOUtils.java:2246)
	at com.k15t.scroll.viewport.request.AttachmentRequestHandler.serveAttachment(AttachmentRequestHandler.java:133)
	at com.k15t.scroll.viewport.request.AttachmentRequestHandler.handle(AttachmentRequestHandler.java:59)
	at com.k15t.scroll.viewport.request.ViewportServletFilter$1.doInTransaction(ViewportServletFilter.java:231)
	at com.k15t.scroll.viewport.request.ViewportServletFilter$1.doInTransaction(ViewportServletFilter.java:205)
	at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:21)
	at com.atlassian.sal.spring.component.SpringHostContextAccessor.lambda$doInTransaction$0(SpringHostContextAccessor.java:70)
	at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:140)
	at com.atlassian.sal.spring.component.SpringHostContextAccessor.doInTransaction(SpringHostContextAccessor.java:68)
	at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.access$001(ConfluenceSpringHostContextAccessor.java:21)
	at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.lambda$doInTransaction$3(ConfluenceSpringHostContextAccessor.java:72)
	at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContextInternal(VCacheRequestContextManager.java:84)
	at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContext(VCacheRequestContextManager.java:68)
	at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.doInTransaction(ConfluenceSpringHostContextAccessor.java:72)
	at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:18)
	at jdk.internal.reflect.GeneratedMethodAccessor275.invoke(Unknown Source)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
	at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
	at com.sun.proxy.$Proxy257.execute(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
	at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
	at com.sun.proxy.$Proxy2941.execute(Unknown Source)
	at com.k15t.scroll.viewport.request.ViewportServletFilter.processInViewport(ViewportServletFilter.java:205)
	at com.k15t.scroll.viewport.request.ViewportServletFilter.processInViewportWithStopWatch(ViewportServletFilter.java:180)
	at com.k15t.scroll.viewport.request.ViewportServletFilter.doFilter(ViewportServletFilter.java:96)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:62)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.lambda$doFilter$0(DelegatingPluginFilter.java:57)
	at com.atlassian.troubleshooting.thready.filter.AbstractThreadNamingFilter.doFilter(AbstractThreadNamingFilter.java:46)
	at com.atlassian.confluence.util.profiling.ConfluenceActivityFilter.doFilter(ConfluenceActivityFilter.java:39)
	at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:56)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:55)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:43)
	at com.atlassian.johnson.plugin.servlet.filter.JohnsonServletFilterModuleContainerFilter.doFilter(JohnsonServletFilterModuleContainerFilter.java:50)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
	at com.atlassian.confluence.util.UserLoggingContextFilter.doFilter(UserLoggingContextFilter.java:32)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
	at com.atlassian.confluence.util.UserNameHeaderFilter.doFilter(UserNameHeaderFilter.java:25)
	at com.atlassian.confluence.web.filter.MauEventFilter.doFilterInternal(MauEventFilter.java:31)
	at com.atlassian.confluence.web.filter.AbstractStaticResourceAwareFilter.doFilter(AbstractStaticResourceAwareFilter.java:43)
	at com.atlassian.confluence.web.filter.ConfluenceTimeoutFilter.doFilter(ConfluenceTimeoutFilter.java:57)
	at com.atlassian.confluence.web.filter.HttpSessionRegistrarFilter.doFilter(HttpSessionRegistrarFilter.java:74)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:242)
	at com.atlassian.confluence.web.filter.ConfluenceSecurityFilter.applyFilter(ConfluenceSecurityFilter.java:40)
	at com.atlassian.confluence.web.filter.ConfluenceSecurityFilter.doFilter(ConfluenceSecurityFilter.java:29)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:94)
	at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:35)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:148)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:67)
	at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:57)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:31)
	at com.atlassian.analytics.client.filter.DefaultAnalyticsFilter.doFilter(DefaultAnalyticsFilter.java:38)
	at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:39)
	at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:37)
	at com.atlassian.confluence.web.filter.HttpRequestStatsFilter.doFilter(HttpRequestStatsFilter.java:58)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:121)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:92)
	at com.atlassian.confluence.web.filter.ConfluenceTimingFilter.doFilter(ConfluenceTimingFilter.java:47)
	at com.atlassian.confluence.extra.webdav.servlet.filter.WebdavRequestForwardFilter.doFilter(WebdavRequestForwardFilter.java:72)
	at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:29)
	at com.atlassian.confluence.util.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:36)
	at com.atlassian.confluence.internal.web.filter.spring.IgnoreWebAsyncManagerFilter.doFilter(IgnoreWebAsyncManagerFilter.java:59)
	at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:51)
	at com.atlassian.confluence.web.filter.TranslationModeFilter.doFilter(TranslationModeFilter.java:39)
	at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71)
	at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:39)
	at com.atlassian.confluence.impl.vcache.VCacheRequestContextFilter.lambda$doFilter$3(VCacheRequestContextFilter.java:44)
	at com.atlassian.confluence.impl.vcache.VCacheRequestContextFilter.doFilter(VCacheRequestContextFilter.java:43)
	at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:33)
	at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:67)
	at com.github.kristofa.brave.servlet.BraveServletFilter.doFilter(BraveServletFilter.java:59)
	at com.atlassian.confluence.web.filter.ZipkinTracingFilter.doFilter(ZipkinTracingFilter.java:52)
	at com.atlassian.confluence.web.filter.ResponseOutputStreamFilter.doFilter(ResponseOutputStreamFilter.java:25)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:37)
	at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:64)
	at com.atlassian.confluence.internal.diagnostics.HttpRequestMonitoringFilter.doFilter(HttpRequestMonitoringFilter.java:42)
	at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:46)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
	at org.apache.catalina.valves.StuckThreadDetectionValve.invoke(StuckThreadDetectionValve.java:206)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
	at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:373)
	at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
	at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1594)
	at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.base/java.lang.Thread.run(Thread.java:834)
Any help would be much appreciated! Thanks!
Craig Nodwell
Hi @Craig Day you might have a cache issue.  Please review this posting for reference.
Craig Day
Hello @Craig Nodwell , thanks for your response.
So these images are available if I perform a restore from the backup and then bring the confluence docker back online. I don't think this could be the cache issues described in your post. In the posting you linked, it seemed that the images were broken from being put into the confluence page. This is not the case with our images. They are there for some period of time and then stop working on certain pages. We're trying to understand what's going on here.
Any additional information would be much appreciated!
SERVER
VERSION
7.5.2
Upcoming Confluence Events
