It is possible to delete blog post automatically after a certain time?
Tobias Groß
December 8, 2013
Hey,
it is possilbe to delete a blog post in Confluence after a certain time?
Tobi
Bob Swift
January 1, 2014
Confluence Command Line Interface can be used without taking Confluence offline or worrying about corrupting your database. Use the query in runFromSql. An alternative for OnDemand or if you don't want to do SQL is to use getBlogList to a csv file and a small script to select rows by date. In either case, use something like:
--action removeContent --id nnnnnnnn
Rodrigo Girardi Adami
January 1, 2014
Matthew's answer can be used indeed. A script can be created to delete blogposts, however, note that the blogposts are inside the "content" table and this table consists of multiple FKs in the database. So, if you are willing to create a script, be sure to not violate any constraint in the process and keep the database clean.
Matthew J. Horn
January 1, 2014
While it's certainly not a built in feature, you could write a SQL statement against the Confluence database that runs at some interval (as a cron job, perhaps) and cleans up/removes entries that are older than a certain date.
AmrtaA January 1, 2014
Hi Tobi,
The answer is no, Confluence doesn't have that functionality.
Amrta
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
