JQL function WAS not working in Confluence
Steve Gibbons
I want to use the Insert Jira Issue/Filter macro in confluence for
assignee WAS first.last
where first.last is the username of the assignee in Jira
This JQL works find in Jira but not in Confluence with the Insert Jira Issue / Filter maco. Can anyone assist with this?
Thank you -- Steve
Rob Horan
March 9, 2021
If you save the filter and then use the saved filter in Confluence do you have the same issue?
Steve Gibbons
@Rob Horan Good evening Rob. This worked perfectly. Thank you. Have a great evening.
Like • Rob Horan likes this
Rob Horan
March 10, 2021
Glad I could help!  If not too much trouble, would you mind selecting this as an accepted answer?
Steve Gibbons
Done. Hopefully this helps others with the same issue. Thanks again Rob!
Rob Horan
March 10, 2021
YW!
