JavaMelody for JIRA configuration
I am using JIRA 7.1.1 with a direct jdbc connection. I am unable to connect to capture MySQL (SQL metrics) for the JavaMelody plugin. I have followed the developer documents but  perhaps I am doing something else wrong. The error message I receive:
Unable to bootstrap application: The database driver (net.bull.javamelody.JbdcDriver) was not found in the class path.
configured from developer site:
Emeric Vernat
April 27, 2016
You should use the plugin for JIRA / Confluence / Bamboo and you should define a datasource.
For details, see:
https://github.com/javamelody/javamelody/wiki/AtlassianPlugin
Emeric Vernat
May 7, 2016
I have just updated the wiki page above for the datasource config when using JIRA 7 (maxTotal instead of maxActive).
Emeric Vernat
April 30, 2016
I have not tested myself in JIRA data center. And yes, I think that the datasource configuration should be applied to each node.
Could you provide an example configuration if I am currently using jdbc direct? How would javamelody be configured if you are planning for JIRA Data Center? Will this configuration need to be applied to each JIRA Data Center node?
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
