Jira Card Layout in Confluence.
Gioele Lai April 28, 2022
Hi dear community;
When I share a Jira Card ticket in Confluence, it shows me only the 'Reporter' but not the 'Assignee'. Actually, what I need is that it shows the 'assignee' and 'collaborators' and not the 'reporter'. It is possible to amend it?
Thanks in advance.
Srinatha Tondihal
April 30, 2022
Hi @Gioele Lai ,
Welcome to Atlassian community.
When you are adding this ticket using Jira macro. After you search the ticket , at the bottom you will have "Display options" when you expand that it will show you all the columns to display. Just remove Reporter from there . You can actually keep only colums you want to see. Try that.
Have a good day!
Cheers
Srinath T
Gioele Lai May 2, 2022
@Srinatha Tondihal Even if I change the options, the card remains as before. However, I have the option of also showing the Jira Macro as columns and these are editable, which helps me with what I was looking for. Thank you very much!
Srinatha Tondihal
May 4, 2022
@Gioele Lai Glad to hear that , the information helped. Yes, Jira macro provides a lot of options. To better understand the same you can go thorough the below URL
Have a good day!
Srinath T
Like Gioele Lai likes this
Brant Schroeder
@Gioele Lai Can you share a screenshot?
Gioele Lai April 29, 2022
Sure, thanks @bran
To be clearer, the issue I am experiencing is not with the Jira Cards in the Jira platform but when they appear in Confluence.
Srinatha Tondihal
April 30, 2022
@Gioele Lai ,
You can actually refer the below web page and get an idea about customising columns to display from Jira.
Refer to the screenshot below " To display a table of issues based on a JQL search".
Srinath T
