When I am using a Jira issue macro in confluence, its showing wrong format in case of text Custom fields.
However, in case of system fields (for example Description and Environment field in the attached screenshot) its showing the exact formatted text as in Jira... this issue only happens when it is a Custom field (for example Resolution Details and Text2 field in the attached screenshot), its showing HTML format.
Below are the exact values in for both ethe custom fields:
Resolution Details: REsolution done
Text2: Details: Test
Current confluence version: 8.5.5
Hi @Asan Nayek
You are facing this issue: https://jira.atlassian.com/browse/CONFSERVER-94113
You can watch it to be informed when the ticket is resolved.
Regards
I am encountering the same issue. Custom field in Jira with carriage return is showing up in Confluence with carriage return represented as the HTML equivalent for a "breaking return". Refer to image for display differences. HELP!
Hi
You need to update Confluence to a version that has the fix listed in the ticket I mentionned.
Regards
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
