My two applications (JIRA and Confluence) are connected with app links. It gets data from JIRA for Issue counts, but do not show anything when I used the display option 'table'. Please let me know if any pointers to start my trouble shooting.
Thank you,
Siva
Hi Siva,
I presume you're using the JIRA Issues macro, and when you run a query it will return a value if you select "Total issue count", but if you change to "Table" it doesn't return any data.
Is that correct?
