Jira macro - 500 http
Ajay Kamble January 30, 2014
when I try to insert jira macro in confluence it gives me
"Received the following HTTP error code from the server:500"
what could be cause of it ?
I have added Ondemand Jira to confluence as follows,
<th>Application</th><th>Primary</th><th>Name</th><th>URL</th><th> </th>
JIRA Yes OnDemandJira
https://xyz.atlassian.net
Roman Samorodov
November 16, 2016
Turn on the oauth authentication in both JIRA and Confluence.
In JIRA go to Application Links click Edit -> Outgoing Authentication -> Oauth and click Enable.
The same steps for Incoming Authentication in JIRA.
Also you should do the same in Confluence.
Akeles
January 28, 2015
You might want to recreate the applinks between JIRA and Confluence again.
