Keyboard shortcut for monospace formatting
jeenuv October 23, 2019
Is there a keyboard shortcut for formatting a selected text as monospace? Alternatively, is there a special trigger, like { character triggering a macro chooser?
When writing technical documentation, there would inevitably be text that needs to be formatted in monospace. It's a pain to repeatedly select text, reach for the A icon on the toolbar, and then selecting 'Monospace'.
Gustav L'Estrade
October 23, 2019 edited
Hello @jeenuv ,
I am not aware of a keyboard shortcut for formatting text as monospace. According to this link there is a shortcut (ctrl + shift + m), but that didnt work for me. The solution that i am using is to do markup as {{text to be formatted in monospace}}. The double curly-brackets at the start and end of the text does the job. Its not a keyboard shortcut, but it is simple and easy to do.
To see all available key shortcuts and markups, press the "?" in the top right corner of the window when editing a page in confluence.
Hope this helps,
Good luck with your Confluence endeavors!
jeenuv October 23, 2019 edited
{{ }} works for me, although I still itch for a shortcut (just like to make text bold/italic). Meanwhile, I've reported an error on the page you linked.
And I've never spotted the ? while editing pages either!
Thank you for the pointers!
Like • Gustav L'Estrade likes this
Bob Sovers
October 24, 2019 edited
Your method only works on Confluence Server
Tom Hundt
October 19, 2020
Ctrl+Shift+M is Insert Media; the closest thing to a shortcut is Ctrl+7, but that (like the other Ctrl+number shortcuts) operates on a paragraph basis.  Atlassian is just lame.
Bob Sovers
In Confluence Cloud, placing ` to either side of a character string shows the text as monospaced (In the new editor, this also includes a grey background, in the old editor it is just the regular background color)
Also, the ? has moved to the bottom-right in the new editor!
You may also use the /Code macro to insert a formatted code "snipett", with some syntax highlighting, etc.
coden
December 16, 2021
I've created own TamperMonkey script to use Ctrl+m to add Monospace formatting
https://gist.github.com/dmitryuk/05768cc3386dffecc5d22d9f827f24d8
zubair khalid
Banned
December 7, 2023
Your technique simplest works on Confluence Server. can you plz check this problem on my https://spacebarclicktest.info/cps-test/ this page ?
