Knowledge base custom fields
a.sahin01 June 30, 2020
Hi all,
We would like to add custom fields such as Product. Module and Customer checkboxes so that the support stuff can select the module or customer regarding the problem solution.
How can it be done with these requirements?
Armagan
Davin Studer
June 30, 2020
I would recommend using labels for this. That is the default means of categorizing and grouping types of content within Confluence.
Hi Davin,
Thank you for the reply. Can you give an example on how to make a checkbox for our custom field named "Product"? I am new to this concept.
Armagan
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
