LaTeX and markdown
Catherine Dalzell
December 27, 2018
Is it possible to include mathematical equations and symbols, by way of LaTeX, using Markdown in Atlassian?
Sid
December 27, 2018 edited
Catherine Dalzell
December 27, 2018
Thanks. I'll ask my admin to install it for us.
Ghanaati Ali
June 19, 2023
Similar question here;  if the markdown contains a mathematical formula, how does confluence support such a format?
a short part of the markdown file:
S(s)=\sum_{i=1}^{3}\frac{\alpha _i}{\tau _i S + 1}
where $\alpha_i$ is the weight factor for the filter and for each filter $i$,
Oki__PolarisOffice_
January 26, 2023
@Catherine Dalzell
If you are looking for a way to add LaTeX in confluence pages, I would recommend
LaTeX EASY math equation for Confluence .
You can choose inline/ block mode when you add LaTeX. As well as, it provides real time preview and selectable formula entry UI so you can easily add and edit formulas.
Parva C_ - Narva Software
August 18, 2021 edited
Hi Catherine,
If you are looking to write math formula in Confluence pages, you can use add-ons which provide that feature.
If Markdown is not a hard requirement, we recently released an add-on which allows rendering LaTeX as well as AsciiMath and MathML expressions in Confluence.
Please try out LaTeX Math for Confluence available at Atlassian Marketplace.
Let us know if you face any issues.
Parva
