Label Management
Sean Gorman
Is there no way in Confluence to create global labels which are allowed to be chosen from?
Seems like basic functionality that should exist. If I leave the labels open to anyone to create we are going to get a large variation of the same thing. If the labels are created before hand and chosen from then there's a standard.
Guilherme Nedel [Atlassian]
April 23, 2014
Hello Sean, there is a feature request for such registered under this ticket. In addition to this, curently there are a number of add ons that extend the bundled application functionality particarly, Labels Cage.
April 24, 2014
Hi Sean, if this answer helped you, kindly mark it as accepted at the top right corner, as such it can help other people too. :) thanks
