Macros - not working after confluence upgrade
Karolina February 27, 2014
I used to have macros in confluence pointed to jira, but after I upgraded confluence to version 5.4.3 I get error:
com.atlassian.confluence.macro.MacroExecutionException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I use SSL certificate for jira and confluence. It’s setup on apache which is connected to tomcats using AJP.
I don’t have encryption directly on tomcat servers.
Everything was working fine (until upgrade) and I didn’t have to import SSL certificate, to establish connection between confluence and jira.
I was trying to fix the issue by importing apache SSL certificate to confluence like in this tutorial: https://confluence.atlassian.com/display/JIRA/Connecting+to+SSL+services
After import I’m getting error:
com.atlassian.confluence.macro.MacroExecutionException: Unable to connect to site specified: Connection refused: connect
What else should I do ?
regards
Karolina
William Zanchet [Atlassian]
February 27, 2014
Hi Karolina,
I'd take a look in this documentation, that explain why we're getting such error:
https://confluence.atlassian.com/display/STASHKB/SSLHandshakeException+-+unable+to+find+valid+certification+path+to+requested+target
I know is a Stash documentation, but it the same principle. The steps are the same.
Also, I'd use SSLPoke to do the testings to see if everything is correct as this documentation shows:
https://confluence.atlassian.com/pages/viewpage.action?pageId=186712330
I hope this helps.
WZ.
Karolina March 19, 2014
Hey,
Couse of the problem was certificate.
I found out that certificate which I download with “Portecle” application has smaller size than certificate that I actually use on apache server.
When I used certificate directly copied from apache everything went fine.
Thanks for help :)
