Making edit restrictions inherited
Shannon Ng December 17, 2018
Is there anyway for edit restrictions created on a parent branch to be inherited to the child branch?
Shannon Meehan _K15t_
Hey @Shannon Ng ,
Not sure if the plugin that Patrick recommended did the trick, but if not, my team here at K15t just added this feature into our Scroll Documents app. Again, another plugin so not always ideal, but the way the app works is you’re can define a page tree or a collection of pages in Confluence as one unit and then manage these pages together.
So in your case, you could containerize that parent page and its children, and then set the restrictions across all the pages inside of a single UI. If you need to update the view or edit restrictions, it then applies to all the pages at once. You can read more about it here.
Of course, this isn’t the only functionality of the app. You can also version page trees, set workflow statuses, send read requests, and export to PDF or Word with our Scroll Exporter apps, and more.
If you have any questions, we'd be happy to help or show you a demo of the app. Just get in touch with us: hello@k15t.com.
Shannon (K15t)
Patrick Cartier [Candylio]
December 17, 2018
Hi @Shannon Ng welcome to the community!
Unfortunately out of the box "View restrictions are inherited, which means a restriction applied to one page will cascade down to any child pages.  Edit restrictions are not inherited, which means pages need to be restricted individually."
As you can see here: https://jira.atlassian.com/plugins/servlet/mobile?_ga=2.76599574.2019710780.1545018989-1760366298.1538725681#issue/CONFSERVER-5095
This has been an open ticket since 2006 and Atlassian still aren't sure if they will implement it or not!
December 17, 2018
An option I just found from this answer: https://community.atlassian.com/t5/Confluence-questions/Making-edit-restrictions-inherited/qaq-p/889917
Is using power scripts for confluence, that would require buying a plugin though.
Not sure why Atlassian take so long to implement this request since it have been open for more than a decade.  It is very painful to have to set the edit restrictions for every single.
Like • Dorothy Bartoszewski likes this
December 17, 2018
If you read the comments on the ticket, you'll see that there are good arguments for each side (to inherit or not inherit edit restrictions).  Some people feel strongly each way.  It's difficult to make a decision when opinions are so split.  In the meantime a good option is using a plugin, therefore the users who want the feature can have it and those who don't want it, don't have it forced on them.
Thanks!  Where can I get more information on the plugin?
December 17, 2018
New Confluence Admin Learning Path! 🤩
Confidently manage users, permissions, and content in Confluence. This self-paced learning path helps admins streamline collaboration, improve user experience, and apply the best practices to get the most out of Confluence in any cloud environment.
Start Learning Now
