Manual upgrade of Confluence from 3.3 to current release
s
Hi
A question on the upgrade path from 3.3 to current release.
From the documentation it says
2.8 to 3.4
Manually upgrade to 3.5.17, and follow paths below.
What do you mean when you say Manually upgrade ?
Can the confluence be upgraded using a built in function for upgrades
OR
 Do I have to download the version given and then go through the steps covered in the section Performing the Upgrade from relevant version.
Aleš Laňar
September 17, 2014
You have to upgrade to 3.5.17, then upgrade to 4 and then to 5 smile Manually is that you cant go directly  to latest versionsmile
Tiago Comasseto
September 17, 2014
Manually also means that you need to use the zip/tar.gz installation packet, instead of the installer wizard.
Cheers
Aleš Laňar
September 18, 2014
And yes that is true.. But when you have to upgrade this interversion, you dont have any other chance :)
