Max Number of Multiexcerpts Per Page or Space
Melissa Henderson March 11, 2014
Is there a maximum amount that the multiexcerpt and/or multiexcerpt include macros can be used within a page or a space?
Right now I am experiencing an issue where I can add the multiexcerpt macro to a page, name it, and preview the content fine. When I add the corresponding multiexcerpt include macro to a different page, I get this:
Excerpt not found
The page: Proper Page Name was found, however, the excerpt named: myexcerptname was not found. Please check/update the excerpt name.
I am using the multiexcerpt macro quite heavily on a single page (its an error code repository), and am wondering if I simply have too many instances of the macro. The pages that use the multiexcerpt includes have, on average, five instances of the include macro. Another consideration is that we had the trial version installed, and a purchase request approved; however, I don't know if IT has installed the paid version (I can't get an answer). Would that have anything to do with it?
I am using Confluence 4.3 with the Documentation theme.
Brendan Patterson
April 27, 2014
Hi Melissa,
Apologies I'm only just this moment seeing this question.
First there is definitely no maximum number of multexcerpt per page. I recently added a "caching" feature for the (BTF version - there is now also a MultiExerpt for OnDemand ) to support someone with ~600 "multiexcerpt-includes". They were seeing 2 minute page loads which went down to ~2 seconds.
The trial version is fully functional.
My best guess is that there could be a typo? Double check the pagename and excerpt name in both places? Also try recreating both (not that I've seen this help but worth a try).
If none of this helps then please open a ticket by sending a note to:
help (at) artemissoftware.freshdesk.com
thanks!
Brendan
Melissa Henderson April 28, 2014
Thank you for the response. I've reworked the page to get around the issue I was having, but if I encounter the issue again, I will follow your recommendations.
