×Hi Team,
I am trying to switch over from my own server to cloud. I thought doing an export/import would do the trick, but unfortunately I ran into the old backup problem (which I worked around by doing a backup on server-based tools like database- and file backup).
Clicking "backup" on the backup and recovery page, I get the error:
javax.servlet.ServletException: Servlet execution threw an exception
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:315)
caused by: java.lang.NoClassDefFoundError: javax/xml/bind/DatatypeConverter
at com.atlassian.dbexporter.node.stax.StaxStreamWriter$1.setContentAsBinary(StaxStreamWriter.java:108)
I experienced that on several version, here: 6.3.4 build 7202
Linux 3.16.0-4-amd64
Apache Tomcat/8.0.43
Java 1.8.0_131
What can i do?
BR
Axel
Hi Axel,
As Michael mentioned, before migrating from a Server instance to a Cloud instance, we always recommend that you're on the most recent version. Have a look at Confluence Server to Confluence Cloud documentation for the full set of instructions. However, your version of Confluence is still new enough that it may be possible.
Now as far as your error goes, it is caused by this problem: Cannot create XML backup due to "Could not read fields for table" Unknown ActiveObjects Table. Please have a look at the diagnosis in order to determine which table it is you need to remove.
Let me know if you run into any further issues or have any questions!
Kind Regards,
Shannon
Hi Shannon,
thanks for your reply. Concerning the XML error I have to state that is it not possible to DROP the table, because it does not exist. If found in the log:
2017-10-11 08:42:09,092 INFO [http-nio-8090-exec-1] [activeobjects.confluence.backup.LoggingBackupProgressMonitor] beginTableBackup Begin backup for table : AO_DCA036_ENCRYPTION_KEY
2017-10-11 08:42:09,094 WARN [http-nio-8090-exec-1] [confluence.impl.hibernate.ConfluenceHibernateTransactionManager] doRollback Performing rollback. Transactions:
->[null]: PROPAGATION_REQUIRED,ISOLATION_DEFAULT (Session #1053197317)
Showing 10 last transactions at this level out of 192 in total:
[com.atlassian.confluence.upgrade.upgradetask.EmbeddedCrowdAddMissingConstraintsUpgradeTask.getShortDescription]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #1906139359)
[com.atlassian.confluence.upgrade.upgradetask.EmbeddedCrowdAddMissingConstraintsClearDataUpgradeTask.breaksBackwardCompatibility]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT (Session #1285352114)
[com.atlassian.confluence.upgrade.upgradetask.EmbeddedCrowdAddMissingConstraintsClearDataUpgradeTask.getBuildNumber]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #2042684925)
[com.atlassian.confluence.upgrade.upgradetask.EmbeddedCrowdAddMissingConstraintsClearDataUpgradeTask.getShortDescription]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #2057451761)
[com.atlassian.confluence.upgrade.upgradetask.AttachmentRemoveFileStoreIDsUpgradeTask.breaksBackwardCompatibility]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT (Session #1690586835)
[com.atlassian.confluence.upgrade.upgradetask.AttachmentRemoveFileStoreIDsUpgradeTask.getBuildNumber]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #1144197179)
[com.atlassian.confluence.upgrade.upgradetask.AttachmentRemoveFileStoreIDsUpgradeTask.getShortDescription]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #883502164)
[com.atlassian.confluence.upgrade.upgradetask.ContentIndexUpgradeTask.breaksBackwardCompatibility]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT (Session #1479694419)
[com.atlassian.confluence.upgrade.upgradetask.ContentIndexUpgradeTask.getBuildNumber]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #495945907)
[com.atlassian.confluence.upgrade.upgradetask.ContentIndexUpgradeTask.getShortDescription]: PROPAGATION_REQUIRES_NEW,ISOLATION_DEFAULT,readOnly (Session #1463822182)
-- url: /confluence/admin/dobackup.action | traceId: d141a006b7b3ce77 | userName: (REMOVEDFORPRIVACYREASONS)| referer: (REMOVEDFORPRIVACYREASONS)
2017-10-11 08:42:09,096 ERROR [http-nio-8090-exec-1] [[Standalone].[localhost].[/confluence].[action]] log Servlet.service() for servlet [action] in context with path [/confluence] threw exception [Servlet execution threw an exception] with root cause
Entering postgresql and trying to drop the table psql tells me it does not exist:
postgres=# DROP TABLE "AO_DCA036_ENCRYPTION_KEY";
FEHLER: Tabelle »AO_DCA036_ENCRYPTION_KEY« existiert nicht
How can I succeed?
BR
Axel
Hi Axel,
That is odd, because it does appear the table is there due to the errors.
Can you be sure you're in the correct database? I have another customer I found that received the same error about that exact table not existing, but tried again using the command on the correct table, and was able to drop it.
Kind Regards,
Shannon
Thanks Shannon,
not being familiar with SQl (and almost absolutely not with postgresql) I totally missed to change to the dabase. Sorry for that! Worked now! Result:
Backup done, request finished. Thanks a lot, close and forget. :) I documented that (hihi, in confluence). For whom it may help (linux debian with postgresql:
less /var/atlassian/application-data/confluence/logs/atlassian-confluence.log
(search for beginDatabaseInformationBackup)
(search for ERROR)
(go some lines upwards, to find the last table before the error)
sudo -H -u postgres psql
\l
\c confluence
\q
Hi Axel, Are you doing this backup from the latest updated copy of JIRA? Your server should be updated to JIRA 7.5.X prior to performing the migration to Cloud: https://confluence.atlassian.com/jirakb/migrating-from-jira-server-to-jira-cloud-779160826.html.
For the specific problem above, I think this article in the Knowledgebase will help: https://confluence.atlassian.com/jirakb/jira-xml-backup-fails-throws-java-lang-noclassdeffounderror-javax-xml-bind-datatypeconverter-895910465.html
