Mobile view confluence 5.1.5 not working properly.
Michael Monette
Hi, just upgraded to Confluence 5.1.5. All is well, except the beautiful mobile view is not working properly. Popular shows "No Content". Blogs shows a few. But the most important is the search. It simply loads forever.
Even browsing to the mobile mode on my PC ( http://confluence.x.com/plugins/servlet/mobile ) I experience the same issue. I was not able to find any mobile issues on google for Confluence 5. Anyone have any ideas that could help solve this issue?
William Zanchet [Atlassian]
August 16, 2013
Hi Mike,
I just installed a Confluence 5.1.5 from scratch, and I was able to see my content under Popular tab. I've access through my iPhone 4S.
As far as I know, such problem could be caused by the index, because it just gets all the updates from the page. So I suggest you to do a rebuild of indexes from scratch to see if it will fix this problem:
https://confluence.atlassian.com/display/CONFKB/Rebuild+the+Content+Indices+from+Scratch
I hope this helps.
WZ
