Monitor Confluence plugin updates via UPM and Nagios
M_S_
April 10, 2015
I would like to monitor Confluence plugin updates through Nagios. Whenever an update becomes available, Nagios should trigger a warning.
I can do the Nagios part, including any scripting that would be needed there. The key question is really how can I query Confluence whether it has any plugin updates available, e.g. via REST.
I have discovered the UPM rest API at /rest/plugins/1.0/, but while it provides a list of installed plugins, this does not seem to include whether an update is available.
M_S_
April 17, 2015
Although it may be feasible, it does not appear to be a good solution. The monitoring would need to query confluence to check what plugins are installed with which versions, parse the REST output and then also check the marketplace, somehow parse that HTML(? - uh) and then compare these. Quite some work, specifically since confluence itself already has that logic built-in - when I navigate to the plugins page it tells me which plugins need updates. My hope was for some REST interface rather than parsing HTML which breaks easily (with updates).
Guilherme Nedel [Atlassian]
April 17, 2015
Hello M.S. by any chance would be monitoring Marketplace plugin pages feasible, instead of attempting to retrieve the info from the application itself? For instance, this addon page gets updated with version whenever there are new iterations. Thoughts?
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
