Multiple Issue Collectors on Single Page Not working
Walter Hartman September 25, 2018
Based on security issues, my organization has disabled the HTML macro so we are using the Markdown macro for some HTML functions to work, including the issue collector. I'm trying to get a specific/clean layout for multiple issue collectors to be on a single landing page, but the instructions on layering the code at https://confluence.atlassian.com/adminjiraserver/advanced-use-of-the-jira-issue-collector-938847349.html isn't exactly clear to me as a "novice" user with some basic coding experience.
Here's the setup I have on one page:
1) insert of markdown to create the first button/trigger
2) on a new line, a second markdown to create the next button/trigger to be used
3) a third line using markdown for the last button/trigger on the page
All of the above use the following type of context:
<input type ="button" value ="Request a Finance burning ship extension" id="FNEextension"></input>
then under the table that I have inserted to organize the page and the buttons, I have a final markdown with the code below (some of the script references updated for security reasons):
<script type="text/javascript" src="https://REDACTED/2.0.24/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js?locale=en-US&collectorId=69e8c326"></script>
<script type="text/javascript" src="https://REDACTED/2.0.24/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js?locale=en-US&collectorId=a9f50e3c"></script>
<script type="text/javascript" src="https://REDACTED/2.0.24/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js?locale=en-US&collectorId=3aca9c25"></script>
<script type="text/javascript">
// safely use jquery here since the issue collector will load it for you
  $(document).ready(function() {
	window.ATL_JQ_PAGE_PROPS = $.extend(window.ATL_JQ_PAGE_PROPS, {
		//=== CR collector id in first paragraph for question 1 ===
		'69e8c326' : {
			//=== CR trigger function ===
			"triggerFunction": function(showCollectorDialog) {
			  $("#FDTCR").click(function(e) {
				e.preventDefault();
				showCollectorDialog();
		//=== Inventory collector id in second paragraph for question 2 ===
		'a9f50e3c' : {
			//=== Inventory trigger function ===
			  $("#InventoryRequestTrigger").click(function(e) {
				e.preventDefault();
		//=== Extension collector id in third paragraph for question 3 ===
		'3aca9c25' : {
			//=== Extension trigger function ===
			  $("#FNEextension").click(function(e) {
				e.preventDefault();
</script>
None of the buttons work in this attempted setup; when I attempted to just use the separated trigger function code in the same markdown window with the trigger creation markdown, the first two buttons wouldn't work but then the final button would yet it would pull all forms on the page.
Any advice on how to update correctly?
Brad Martin June 12, 2019
Walter, Did you ever get this to work?  I am running into the same issue.
Walter Hartman June 12, 2019
I did! Here's the way the ending script shows up; and I leveraged a table setup on the page to keep things organized:
<script type="text/javascript">window.ATL_JQ_PAGE_PROPS = {
 '69e8c326' :{
 jQuery("#FDTCR").click(function(e) {
 e.preventDefault();
 'a9f50e3c' :{
 jQuery("#InventoryRequestTrigger").click(function(e) {
 e.preventDefault();
 '3aca9c25' :{
 jQuery("#FNEextension").click(function(e) {
 e.preventDefault();
</script>
Like 3 people like this
Thank you so much!!! That worked for me as well!
Walter Hartman June 13, 2019
Excellent!
Jason Holmes
September 3, 2019
Thanks for sharing Walter! Helped me out too.
V
April 29, 2020
Thanks it worked.
Paul van den Berg
November 12, 2020
Thanks! You really helped me out
satender346
December 3, 2020
Thanks, Working for me as well.
Cyril Egan June 29, 2021
Brilliant!  Works for me too!
Sarah Wright
January 23, 2023 edited
winner
Meant this as a comment on the solution!
mickel
February 14, 2019
I was dealing with the same issue, make sure in Jira you made a "custom" issue collector. That way the normal rendered buttons won't show up on your site either.
Register now
