Hi
The following plugins
RB Filtering - Confluence
RB Filtering - Core
RB Storage - Confluence
RB Storage - Core
RB Storage - Servlet
RB Supplier - Core
RB Support - Confluence
RB Support - Core
are present in a Confluence installation.
are they some sort of extended APIs?
Are any other plugins dependent of them?
Can they be safely removed?
Michael Danielsson
Hi
I got the following answer from ServiceRocket:
For your information, those RB plugins are dependencies which contain functions that commonly used by our main plugins, to ensure it works as it should be.
As per my knowledge, those plugins are provided by thirdparty so if you feel those are not require then you can remove and make sure that those plugins are not used in your confluence
