We migrated from 3.4 to 4.2.4, and had to make use of the Delegated LDAP profile to get it to work when migrating through 3.5.x . There was a migration task we used to migrate the Group permissions then. Now I have been directed to see why Synch LDAP can't be utilized now. It appears that IDs are being populated in the Sync process, but users are not being assigned group permissions.
I need a way to reverse migrate the Group permissions from Delegated LDAP to Sync LDAP? Can anyone provide me some input on how I would copy entries?
I appreciate any assistance.
Lyndon-Michael Gordon
Hi there,
To expand on what Tousif has already mentioned, it's possible to use Bob Swift's CLI to bulk assign group memberships. See the following KB for details:
https://confluence.atlassian.com/display/CONFKB/Migrate+Local+Group+Memberships+Between+Directories
Hello
Lyndon-Michael Gordon,
please refer the below links
Or you would use LDAP with Internal Groups, and then use Bob Swift's CLI Plugin and bulk assign.
Hope this helps you!
regards,
tousif shaikh
