Need help limiting LDAP user sync by security group
Justin Samsel
October 17, 2018
Hello, new user to Confluence here.
I am trying to limit Confluence to only importing AD users that are part of the two AD security groups Confluence-Admin and Confluence-Users. I found this KB that I think is pointing me in the right direction, however I can't write the filter correctly.
In "User Directories > Configure LDAP User Directory > LDAP Schema > Base DN" I have:
OU=MyUsers,DC=MyCompany,DC=com
And in "User Directories > Configure LDAP User Directory > User Schema Settings > User Object Filter" I have:
(&(objectCategory=Person)(sAMAccountName=*)(|(memberOf=cn=Confluence-Admin,ou=MyUsers,dc=MyCompany,dc=com)(memberOf=cn=Confluence-Users,ou=MyUsers,dc=MyCompany,dc=com)))
I'm either trying to do this completely wrong or my syntax is broken somewhere. Does anyone have any guidance on fixing this?
Justin Samsel
October 17, 2018
After more reading and trial and error I figured out I was just writing the DN of the security groups wrong. After correcting them in the example above the proper people are getting imported into Confluence.
Kelvin Latner
October 26, 2018
Hi Justin!
I've been tasked with limiting access to our Bitbucket application to a specific group (Distribution List) in our LDAP directory, which is a few hundred users.  Right now, anyone/everyone in our LDAP directory can sign into Bitbucket, which is thousands of users...  We have limited licenses.  I too have tried to tried several filtering suggestions I've found; however, I haven't guessed the right combo yet...  :/
Would you be so kind as to provide examples of your corrected settings?
Thank You Sir!  :D
kns_jeinhorn
June 23, 2021 edited
Justin wrote "I solved it!" but did not share his solution.
Justin, it sure would be nice if you would share the details.
Like • Nicola J likes this
Nicola J December 8, 2021
@Justin Samsel Any chance you can provide what you ended up with? I have this exact scenario and could do with a hint as to what was wrong in the original DN above...
kns_jeinhorn
In my case, the goal was to sync users who belonged to either one of two security groups.
The Active Directory structure in our company, loosely represented:
corp.mycompany.com             (Domain)
|--Otherstuff1 (OU)
|--Groups (OU)
|--OtherGroup1 (OU)
|--SpecialGroup (OU)
|--IgnoreGroup1 (group)
|--MyGroup1 (***group to be included***)
|--MyGroup2 (***group to be included***)
|--IgnoreGroup2 (group)
|--OtherGroup2 (OU)
|--Otherstuff2 (OU)
I managed to make it work by using the following value for the "User Schema Settings - User Object Filter":
(&(objectCategory=Person)(sAMAccountName=*)(!(useraccountcontrol:1.2.840.1135
Good Luck!
Janet
