Need to know what be the possible test cases for confluence performance testing
Gurbir Kaur November 6, 2023
We are migrating Confluence DC from VMC1 to VMC2 and setting up we want to do performance testing on new environment before going live.
We have a used base of 40,000 users and inputs, what an be the possible test cases, how many concurrent users, what will be scenarios etc.
we are running on 7.11.2 and are planning to upgrade onto 7.13.19 soon.
Tests will be run on 7.13.19 conf version.
Sanjen Bariki
November 6, 2023
Hi @Gurbir Kaur ,
Welcome to Atlassian community .
Please follow the below sheet for the testing
In general:
  • check your links to other content are working, for example, Confluence pages linked to Jira issues
  • check that any apps or app data you've migrated is working as expected
  • test integrations with other products, like Jira, Confluence, or Bitbucket
Also I have attached a screenshot below please do UAT by follow the activity.
Accpet the answer If it helps you.
Sanjen Bariki
These are good cases to start with
Thanks @Sanjen Bariki
Sanjen Bariki
November 6, 2023
Hi @Gurbir Kaur ,
Thanks for your valuable feedback.
Please accept the answer If it helps your, It will help other community members to get the solution properly.
Sanjen Bariki
Gurbir Kaur November 7, 2023
Also how can we get the concurrent users using the confluence at a time ? we have a user base of 40,000 users but not all might be using at same time. SO for concurrent users how can we get that number ?
Like Sanjen Bariki likes this
SERVER
