×"java.lang.IllegalStateException: No Hibernate Session bound to thread, and configuration does not allow creation of non-transactional one here" when I try to use service in servlet-filter, but this service can be used normally in servlet . I can be sure that the entity I get through the service.get() method exists, it is not null and the acquired entity contains data.
I don't know what should be done to solve this problem.
This is my error log
[INFO] [talledLocalContainer] 2022-03-23 14:51:07,058 ERROR [http-nio-1990-exec-2] [[Catalina].[localhost].[/confluence].[default]] log Servlet.service() for servlet [default] in context with path [/confluence] threw exception
[INFO] [talledLocalContainer] java.lang.IllegalStateException: No Hibernate Session bound to thread, and configuration does not allow creation of non-transactional one here
[INFO] [talledLocalContainer] at org.springframework.orm.hibernate.SessionFactoryUtils.getSession(SessionFactoryUtils.java:316)
[INFO] [talledLocalContainer] at org.springframework.orm.hibernate.SessionFactoryUtils.getSession(SessionFactoryUtils.java:194)
[INFO] [talledLocalContainer] at com.atlassian.hibernate.SpringPluginHibernateSessionFactory.getSession(SpringPluginHibernateSessionFactory.java:23)
[INFO] [talledLocalContainer] at sun.reflect.GeneratedMethodAccessor253.invoke(Unknown Source)
[INFO] [talledLocalContainer] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[INFO] [talledLocalContainer] at java.lang.reflect.Method.invoke(Method.java:498)
[INFO] [talledLocalContainer] at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
[INFO] [talledLocalContainer] at com.sun.proxy.$Proxy315.getSession(Unknown Source)
[INFO] [talledLocalContainer] at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
[INFO] [talledLocalContainer] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
[INFO] [talledLocalContainer] at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
[INFO] [talledLocalContainer] at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
[INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
[INFO] [talledLocalContainer] at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
[INFO] [talledLocalContainer] at com.sun.proxy.$Proxy1067.getSession(Unknown Source)
[INFO] [talledLocalContainer] at com.atlassian.activeobjects.confluence.ConfluenceTenantAwareDataSourceProvider$SessionFactoryDataSource.getConnection(ConfluenceTenantAwareDataSourceProvider.java:81)
[INFO] [talledLocalContainer] at com.atlassian.activeobjects.internal.DataSourceProviderActiveObjectsFactory$ActiveObjectsDataSource.getConnection(DataSourceProviderActiveObjectsFactory.java:113)
[INFO] [talledLocalContainer] at sun.reflect.GeneratedMethodAccessor872.invoke(Unknown Source)
[INFO] [talledLocalContainer] at net.java.ao.builder.DelegatingDisposableDataSourceHandler.delegate(DelegatingDisposableDataSourceHandler.java:37)
[INFO] [talledLocalContainer] at net.java.ao.builder.DelegatingDisposableDataSourceHandler.invoke(DelegatingDisposableDataSourceHandler.java:30)
[INFO] [talledLocalContainer] at com.sun.proxy.$Proxy2262.getConnection(Unknown Source)
[INFO] [talledLocalContainer] at net.java.ao.DatabaseProvider.getConnection(DatabaseProvider.java:856)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager.find(EntityManager.java:664)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager.find(EntityManager.java:622)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager.find(EntityManager.java:555)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager$2.invoke(EntityManager.java:203)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager$2.invoke(EntityManager.java:200)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager.get(EntityManager.java:230)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager.get(EntityManager.java:196)
[INFO] [talledLocalContainer] at net.java.ao.EntityManager.get(EntityManager.java:264)
[INFO] [talledLocalContainer] at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.get(EntityManagedActiveObjects.java:84)
[INFO] [talledLocalContainer] at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects.get(TenantAwareActiveObjects.java:261)
[INFO] [talledLocalContainer] at sun.reflect.GeneratedMethodAccessor1153.invoke(Unknown Source)
[INFO] [talledLocalContainer] at com.sun.proxy.$Proxy2754.get(Unknown Source)
[INFO] [talledLocalContainer] at com.demo.plugin.watermark.WatermarkServiceImpl.get(WatermarkServiceImpl.java:37)
[INFO] [talledLocalContainer] at com.demo.plugin.servlet.filter.PdfExportFilter.doFilter(PdfExportFilter.java:35)
[INFO] [talledLocalContainer] at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:62)
[INFO] [talledLocalContainer] at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37)
[INFO] [talledLocalContainer] at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.lambda$doFilter$0(DelegatingPluginFilter.java:57)
[INFO] [talledLocalContainer] at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:56)
[INFO] [talledLocalContainer] at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:55)
[INFO] [talledLocalContainer] at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:43)
[INFO] [talledLocalContainer] at com.atlassian.johnson.plugin.servlet.filter.JohnsonServletFilterModuleContainerFilter.doFilter(JohnsonServletFilterModuleContainerFilter.java:50)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
[INFO] [talledLocalContainer] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
[INFO] [talledLocalContainer] at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:57)
[INFO] [talledLocalContainer] at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
[INFO] [talledLocalContainer] at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:31)
[INFO] [talledLocalContainer] at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39)
[INFO] [talledLocalContainer] at com.atlassian.analytics.client.filter.DefaultAnalyticsFilter.doFilter(DefaultAnalyticsFilter.java:38)
[INFO] [talledLocalContainer] at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:39)
[INFO] [talledLocalContainer] at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:37)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.HttpRequestStatsFilter.doFilter(HttpRequestStatsFilter.java:58)
[INFO] [talledLocalContainer] at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:115)
[INFO] [talledLocalContainer] at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:92)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.ConfluenceTimingFilter.doFilter(ConfluenceTimingFilter.java:46)
[INFO] [talledLocalContainer] at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:38)
[INFO] [talledLocalContainer] at com.atlassian.confluence.util.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:36)
[INFO] [talledLocalContainer] at com.atlassian.confluence.internal.web.filter.spring.IgnoreWebAsyncManagerFilter.doFilter(IgnoreWebAsyncManagerFilter.java:59)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:51)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.TranslationModeFilter.doFilter(TranslationModeFilter.java:39)
[INFO] [talledLocalContainer] at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:39)
[INFO] [talledLocalContainer] at com.atlassian.confluence.impl.vcache.VCacheRequestContextFilter.lambda$doFilter$3(VCacheRequestContextFilter.java:44)
[INFO] [talledLocalContainer] at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContextInternal(VCacheRequestContextManager.java:84)
[INFO] [talledLocalContainer] at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContext(VCacheRequestContextManager.java:68)
[INFO] [talledLocalContainer] at com.atlassian.confluence.impl.vcache.VCacheRequestContextFilter.doFilter(VCacheRequestContextFilter.java:43)
[INFO] [talledLocalContainer] at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:33)
[INFO] [talledLocalContainer] at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:59)
[INFO] [talledLocalContainer] at com.github.kristofa.brave.servlet.BraveServletFilter.doFilter(BraveServletFilter.java:59)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.ZipkinTracingFilter.doFilter(ZipkinTracingFilter.java:52)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.ResponseOutputStreamFilter.doFilter(ResponseOutputStreamFilter.java:25)
[INFO] [talledLocalContainer] at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:37)
[INFO] [talledLocalContainer] at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:64)
[INFO] [talledLocalContainer] at com.atlassian.confluence.internal.diagnostics.HttpRequestMonitoringFilter.doFilter(HttpRequestMonitoringFilter.java:42)
[INFO] [talledLocalContainer] at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:46)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
[INFO] [talledLocalContainer] at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:490)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
[INFO] [talledLocalContainer] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
[INFO] [talledLocalContainer] at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:668)
[INFO] [talledLocalContainer] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
[INFO] [talledLocalContainer] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
[INFO] [talledLocalContainer] at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:408)
[INFO] [talledLocalContainer] at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
[INFO] [talledLocalContainer] at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:770)
[INFO] [talledLocalContainer] at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1415)
[INFO] [talledLocalContainer] at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
[INFO] [talledLocalContainer] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
[INFO] [talledLocalContainer] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
[INFO] [talledLocalContainer] at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
[INFO] [talledLocalContainer] at java.lang.Thread.run(Thread.java:748)
This problem occurs when the service is used to obtain the ao object in the Filter, and only in some cases, so I modified the ao object to be read from the httpsession first. If the httpsession can not get the ao object, then I get ao object from the service, it is avoided this problem. But when I use httpsession , it conflicts with atlas-package command
Hi @lamella ,
Did you solve that problem??
I have the same behaviour, from servlet filter I try to execute aoService for getting data and receive the same error.
Hi @Kiril Filipenkov ,
I have fixed this problem.
In serviceImpl file, when need ues "ao" to query some data in database, then in sometimes, plugin will throw this problem, right?
I replaced the previous ao code with the following transaction code, and then it can run normally.
ao.executeInTransaction(() -> ao.find(t, Query.select().where(sql)));
ao.executeInTransaction(() -> ao.get(t, id));
ao.executeInTransaction(() -> ao.find(t));
ao.executeInTransaction(() -> ao.create(t));
For business reasons, I use soft deletion instead of hard deletion.
I hope it will help you.
It really helped me!
Thanks you so much!
But have so missunderstanding, I already use annotation
@Transactional
public interface AOService {
but it doesn't work with annotation, only after changing the code like in your example it worked. Will read more about that annotation.
I used this annotation at first, but I don't know why it didn't work.
Later, after I refactored aoServiceImpl with transaction code, it can be used normally.
With regard to the ineffectiveness of the annotation, we may have to wait for the official repair or provide relevant explanations or solutions.
As for now, since the transaction code can run normally, let's use it first!
