Sign up Log in
NullPointerException when copying a Space using Copy Space Add-on
beecom AG April 13, 2016
We are trying to make a copy of one of the existing spaces, using Copy Space Add-on.
However, we are getting the following error:
Page Not Found
The page you were trying to reach could not be found. This could be because:
·         The page does not exist.
·         The page exists, but you do not have permission to view it.
In the application logs, we can see there is a NullPointerException.
We recently updated to version 5.8.18. Before, this action could be done without problems
Is this a known problem? Is there a way to solve this problem?
Gonchik Tsymzhitov
February 3, 2020
Hi!
I had the same situation, just add that into app
if (labelManager == null || copy == null) {
return;
https://bitbucket.org/gonchik/confluence-copy-space-plugin-atlassian/commits/9b4b97a508bdc3302e10d2813fec4a5ffe6dc7e0
Klaus Höbarth
September 28, 2020
@Gonchik Tsymzhitov any chance that you publish the app somewhere?
Heiko Feisel
December 16, 2020
I have the same question. Do you published this fixed vesion anywhere?
Im not able to compile java code.
TechTime Initiative Group December 16, 2020
Have compiled this on my computer straight from Gonchik's code.
I will upload to Google drive when I get home.
Please send a reminder for me to do it if I forget to ammanueladdis@gmail.com
EPS Software Engineering AG
June 20, 2016
Have a look at our Add-on. You can copy spaces or you can create new spaces based on templates.
Marketplace link: Space Tree Creator
Stephan
Diogo Guerra
June 20, 2016
We also have the same problem. Any updates here?
