I have a table in Confluence that shows a selection Jira projects and by using the Jira issue filter I am able to fill in the columns for Created, Un-Assigned, and Resolved. In the last column I would like to return the Jira Project Lead. Any ideas?
Hi, @DSell !
As I know there is no possibility to make it out-of-box, because Project Lead it is project’s attribute, not issue’s attribute.
If you have any external apps in Jira you can set project lead value in special custom field…but I’m not sure that it is really useful🤷♂️
@Alexander Bondarev , thank you Alexander. That is what I assumed, but knowing that when I do an export, one of the fields on each and every issues is "Project Lead", so I thought I be lucky.
David
