Is it possible to create a simple table inside Confluence that displays all the releases you have in a specific JIRA project?
Basically the same with JIRA Macro that displays all the epics, user stories and so on that you have in a project but only for releases.
Thanks.
oh! you have asked same question twice.
You can delete this one if you want to continue with other one.
This is not directly possible. But you have two options,
