PDF Export not properly works with symbols
Donatella Bria July 20, 2021 edited
I have a problem exporting in PDF a page with some symbols (ie arrow).
Exported page not display properly the symbols but replace them with some chars.
See attached file that shows confluence page and exported pdf page.
I tried to import some ttf file in order to extend the PDF Export Language but its doesn't works.
Are there other workarounds or can you tell me correct ttf file to install?
Thanks in advanced,
Donatella
Donatella Bria August 4, 2021
Hi Brant,
thanks for your reply, but this topic doesn't help me. I doesn't need to add title, header or footer to my export, but to allow to simbol exporting correctly.
I have tried to import some font (ttf file) but any has fixed my problem.
Brant Schroeder
@Donatella Bria The article explains how to add custom fonts which is the issue you are having with the symbol.
