Page 'jumping' in edit mode when trying to edit links
Shimrit Janes February 16, 2018
While editing a page (confluence v6.4, IE11) that has a long table with hyperlinks in it, the page 'jumps' to the top of the page and then back to where your cursor is when you click a link to try and edit it. Additionally, the context menu doesn't show as it should.
Has anyone else experienced this? How can it be resolved?
Nic Brough -Adaptavist-
February 16, 2018
Are you using compatibility mode in IE?  If so, turn it off and try again.
It's a client's setup, so we'll need to ask their IT department. Shall raise the question; it may be that there are wider ramifications to turning off compatibility mode, if it's in use.
Shimrit Janes May 21, 2018
Hi Nic - I can confirm that compatibility mode isn't switched on. Is there any other reason the page could be 'jumping'? The layout uses sections, and the content is also in a table of contents zone; could that be causing issues?
Amit - Blue Sheen June 17, 2018
@Nic Brough -Adaptavist- if it's not compatibility mode, what else would be the possible reasons?
June 21, 2018
A bug in Confluence (although that would be affecting everyone), a bug in the IE you are using (not unlikely, as IE is known to be a poor browser), or an add-on injecting something into the javascript which has a bug.
I'd try turning off all the add-ons (temporarily) and seeing if the problem still occurs.
Peter Kearney
October 27, 2021
I use Chrome and I am getting the same problem. It's so frustrating.
Learn more
