Page restrictions cause timeout
Roman Holdener
Hi
One of our Confluence users is in charge of a page tree with about 2500 sub-pages. Viewing the page is restriced to certain users and groups. The user told me that it is no logner possible to ad or remove users or groups to that page. After clicking to "Apply", nothing happens until Confluence runs into a timeout. It is also not possible to remove all restrictions, as the same behavior occurs. I even tried to remove the restrictions from "Space Administration - Restricted pages", but that didnt't work eighter.
Does anyone know a similar problem or does anyone know a workaround to fix that? One possibility would be to let the parent page open to te public and only set restrictions to some subpages, but as mentionned, I couldn't even remove all the restrictions on the parent page.
There is a bug in Atlassians long term Backlog, referring to a similar problem, but it is not quite sure if my probmlem is caused by that:
https://jira.atlassian.com/browse/CONFSERVER-36912?error=login_required&error_description=Login+required&state=86061148-a9ab-416b-81c1-9cca6fbdb56e
Monique Khairuliana[ServiceRocket]
July 7, 2020
Seems like a performance related issue: Failed to add entry to queue when changing view permissions on a big page tree.
Probably increasing Confluence's resources like increasing the timeout, or the connection to the database would do the trick, and maybe do it on low peak hours.
Or you could hack the database instead: How to remove all restrictions from a specific page via the database
Roman Holdener
Thank you very much for your reply. I will check if raising ressources could help. The database "hack" is also a good idea, but I will only do this if abolutely neccessary.
SERVER
VERSION
6.13.6
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
