Plugins/ themes not working as expected on Confluence DC after restoring from backup
Yohaan Sunny
I just set up Confluence DC on AWS using the cloud formation template provided by Amazon. Everything is installed and configured correctly.
We needed to restore our existing confluence to this new environment and for that, we performed a backup of the existing one and restored to the new one on AWS. This is the Atlassian documentation we followed for the restore: Restore Confluence
The import finished successfully and looks like all the data has come into the new one without any issues, however, the custom themes and plug-ins have not. This is a problem as the site layout and functionality is very different from our existing confluence site.
The Confluence version we are using is 6.2.2
Fadoua
July 13, 2018
Hi Yohaan
If you did the restore through the UI then you will have to configure the theme and re-install plugins. If you do it through the command line then your plugins and theme should remain there.
Yohaan Sunny
Hi Fadoua,
Could you please tell me how I perform the restore through command line?
Is there some documentation on this that I can follow?
Fadoua
July 15, 2018
Hi Yohaan,
What OS and Database are you using?
We have Linux RedHat and MySQL, after creating a dump using command line as well. I use the following:
mysql -u [new_user] -p [database_name] < [file_name].sql
Going back to your question that i missed to answer there is no Atlassian Documentation. I Learned to do it this way from a Sr. DB Admin. We create a dump and then restore it. Try it in a test environment before doing it in Production.
Yohaan Sunny
Hi Fadoua,
I have resolved the issue.
Took a backup of the Postgres database and restored it to a new RDS instance on AWS.
After re-configuring the confluence site to connect to this DB the issues seem to be resolved now.
It's a shame that AWS doesn't let you restore a backup to an existing Postgres DB instance.
Thanks for you help.
Fadoua
July 15, 2018
Great! Glad your issue has been resolved.
We are on AWS as well and using RDS.
Fadoua
July 16, 2018
Thank you @Yohaan Sunny for accepting my answer!
Have a great day!
