From the official Google docs about Google Charts I see in the example "Density of Precious Metals, in g/cm^3" I can annotate the value of the bars at its end by adding
var view = new google.visualization.DataView(data); view.setColumns([0, 1, { calc: "stringify", sourceColumn: 1, type: "string", role: "annotation" }, 2]);
And then pass view at the draw() function.
My current code to display a bar is simple as:
<script> PocketQuery.chart('BarChart', { height: 700, chartArea: { height: '100%', width: '50%' } }); </script>
Hi Stefano,
Sorry for the late reply! In your case, you need to manipulate the data array for the charts. You can achieve this that way:
<script> (function() { // Create a new data table object in which the first row already contains // the table headers. var dataTable = [['col1', 'col2', {role: 'style'}]]; // Iterate through the PocketQuery result and add the values to the data table. You can do arbitrary manipulations with the data before. jQuery.each(PocketQuery.queryArray(), function(index, row) { dataTable.push([row.col1, row.col2, '#ccc']); }); PocketQuery.chart('AnnotationChart', {dataTable: dataTable}); }()); </script>
You should try around in your developer tools and the JS debugger to dig more into this surrounding. Let me know if you need further help!
Regards, Felix [Scandio]
