Possible issue when creating a page
Tim Ruijters May 14, 2018
When I create a page in IE or Chrome (latest versions) it takes very long. Is this a known issue?
Krisztian Kovacs
May 14, 2018
hi Tim,
can you check if the jira server (if it's server) is eating up all the processors? Maybe a restart helps if it's just a random error.
if it's cloud, you can check out https://status.atlassian.com/
so ultimately, is this a one off thing or are you experiencing this issue all the time? what about others in your team?
Tim Ruijters August 23, 2018
I'm working in the cloud. Thanks for the tip regarding status.atlassion.com
Charlie Misonne
Hi Tim
Is this for Confluence Server or Cloud?
In case it is a server instance: do you see any errors in the log files?
