Post upgrade conversion of markup to new format
Tim_Brigham
I recently upgraded from 3.5.3 to 4.1.9. I did not yet have the tables plus macro installed on my new server when I did so. About 80% of the tables in my documents remain being rendred within a wiki markup window.
Is there any kind of utility that I can run my spaces through now that I have that macro installed to automatically convert these tables over to the new format? I've searched but found nothing but background noise.
HuseinA
April 23, 2012
You should get the latest (4.x compatible) table plus plugin installed first. Once you have those 4.x compatible macros installed, you can then re-attempt the migration.
Tim_Brigham
Thanks, that is exactly what I needed, thanks.
Bob Swift
April 24, 2012
Table-plus is currently wiki only. Once new version is available (soon), pages will automatically get converted by coNfluence in the background.
Tim_Brigham
@Bob Swift - I came up with that same conclusion after spending a while looking at this. As a workaround I temporarily disabled the offical macro and created a user macro that simply writes a white space onto the page. At least it renders in the editor this way. Looking forward to this being fully functional again. :) Great plugin.
