For some reason the calendar stop working and we have to refresh a few times to get the calendar working. Here is the following error we are getting
2012-09-21 03:59:49,421 ERROR [TP-Processor3483] [atlassian.confluence.pages.DefaultAttachmentManager] getAttachmentData Could not find data for attachment: Attachment: INTRA v.10 (1310721) jn - java.io.FileNotFoundException: /opt/confluence/.confluence-3.2.1-home/attachments/ver003/167/212/1212417/149/179/1179649/1310721 (No such file or directory)
– url: /download/attachments/1179649/INTRA | userName: abc | referer: https://confluence.mydomain.com/display/spacename/project_name
2012-09-21 03:59:50,205 ERROR [TP-Processor3483] [[Standalone].[localhost].[/].[action]] log Servlet.service() for servlet action threw exception
java.lang.ClassCastException: com.atlassian.confluence.spaces.SpaceDescription cannot be cast to com.atlassian.confluence.pages.AbstractPage
Leap
Hi!
I'm not sure if the errors you provided are related to the calendar's issue.
Although I suggest you to perform a test, checking the last log entries in the same moment the issue occurs.
Also, this might be related to other plugins, like Global Search Filter. So if you have this plugin in your Confluence instance, please disabled it and see if there's any difference.
Cheers!
Yes, you are probably right. but it was the only error when we loaded the calendar. If you look at the attachment I send you, you will see the blank page which suppose to display the canlenar. If we refresh a few times it will be displayed.
This is the calendar code defined
{calendar:id=firstmeetingrooms}
and calendar page
See inside
