Problem adding a label to an attachment using the Confluence UI REST API
soelizab2
July 16, 2013
I'm trying to use the Confluence UI REST API and do a POST request to add a label to an attachment. I tried using curl to do this, but I keep getting an error in HTML, with title "Oops - an error has occurred - Confluence." My command looks like this:
curl -u $username:$password -X POST -H "Content-Type:application/json" -d @data.json ${hostname}/rest/uri/1.0/attachment/${attachmentID}/labels
The data.json file contains:
{"name": "test", "id": 8787878}
I am able to use the the GET and DELETE methods in the Confluence UI REST API with cURL. I'm not sure if the data from the JSON file is in the correct format or even the correct data and I am providing an arbitrary id.
Nitram
July 16, 2013
Try to change the data part, the way you send the data,
The following curl will help you to post the data to server, try it.
curl -D- -u admin:admin -X POST --data {\"body\":\"hello\"} -H "Content-Type: application/json" http://localhost:2990/jira/rest/api/2/issue/TEST-1/comment</code<>>
I dont know whether it is correct, But do let me know.
Hope this helps!
soelizab2
July 16, 2013
Thanks. I tried with the new format of data, but it doesn't seem to work for this particular situation in Confluence. Your answer probably works for adding comments to JIRA issues, and I'm assuming that the data format will be different since I'm trying to pass label information to an attachment.
