I have a confluence backup from a 4.3.2 instance and i'm trying to restore the file in a confluence version 5.5.6. I'm getting the following error message:
Import failed. Check your server logs for more information. com.atlassian.confluence.importexport.ImportExportException: Unable to complete import: Error while importing backup: Failed to lazily initialize a collection
Anyone one have an idea of what could be causing this?
Thanks in advance!
Howdy Omar!
I'd futher recommend importing the 4.3.2 backup to an instance of 4.3.2 and then perform an upgrade to 5.5.6 directly from that. While Confluence does support backwards compatibility for XML backups, this does not include doing a restore of a different major version (ie. 4.x to 5.x) per Restoring a Site.
To fix the error you are getting, setting the database to use UTF-8 as outlined in Alexey's first link should do the trick, but please consider my recommendation.
Stephen Brannen | Confluence Support
Read more 📚Online forums and learning are now in one easy-to-use experience.
