Problem with Confluence behind Nginx
mkrupniewski-blueowl November 20, 2019 edited
I installed Confluence on my own VPS server (in /var/www/atlassian/confluence/ directory), I also configured SSL. In order to connect Confluence to my own domain I did everything according to this manual.
Unfortunately, when I enter my subdomain I get information about error 404 (some simple HTML from Confluence exists), in the browser console a lot of errors about missing resources and strange URLs (e.g. https://my.subdomain.com/s/a5b9cfe2e93be163560b16bfe0aa76f7-CDN/gsrvpz/8301/s1264995706/8.3.5/_/download/batch/com.atlassian.auiplugin:split_aui.splitchunk.vendors--57570d46fb/com.atlassian.auiplugin:split_aui.splitchunk.vendors--57570d46fb.js?locale=en-GB).
I restarted Confluence and NGINX and PHP-FPM and it didn't work.
I've been on it for a couple of hours and I don't know what to do anymore.
Below is the nginx configuration file:
server {
listen my.subdomain.com:80;
server_name my.subdomain.com www.my.subdomain.com;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/my.subdomain.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/my.subdomain.com/privkey.pem;
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers 'ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS';
ssl_prefer_server_ciphers on;
location / {
client_max_body_size 100m;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://localhost:8090/confluence;
location /synchrony {
proxy_pass http://localhost:8091/synchrony;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
server {
if ($host = www.my.subdomain.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
if ($host = my.subdomain.com) {
and server.xml fragment:
<Connector port="8090" connectionTimeout="20000" redirectPort="8443"
maxThreads="48" minSpareThreads="10"
enableLookups="false" acceptCount="10" debug="0" URIEncoding="UTF-8"
protocol="org.apache.coyote.http11.Http11NioProtocol"
scheme="https" secure="true" proxyName="my.subdomain.com" proxyPort="443"/>
<Engine name="Standalone" defaultHost="localhost" debug="0">
<Host name="localhost" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="false" startStopThreads="4">
<Context path="" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true">
<!-- Logging configuration for Confluence is specified in confluence/WEB-INF/classes/log4j.properties -->
<Manager pathname=""/>
<Valve className="org.apache.catalina.valves.StuckThreadDetectionValve" threshold="60"/>
</Context>
<Context path="${confluence.context.path}/synchrony-proxy" docBase="../synchrony-proxy" debug="0"
</Context>
</Host>
</Engine>
Jeff Turner
November 20, 2019
I think the nginx line:
should be:
to match <Context path="" ....>
mkrupniewski-blueowl November 21, 2019
it helps, thank you!
Thomas Brenna
May 30, 2024
@Jeff TurnerThank you!
I was having a similar issue, and had no clue what it was.
I'd removed the context from location / (i.e. gone from location /confluence => /), but didn't catch the context in the proxy_pass directive.
