I'm following this guide:
https://confluence.atlassian.com/doc/running-confluence-over-ssl-or-https-161203.html
But when I'm try to import the SSL certificate (issued by gandi.net), I get this error:
keytool error: java.lang.Exception: Failed to establish chain from reply
In this document there is a tip with a possible solution using Verisign or GoDaddy certificates, but I don't understand how to apply this solution.
Any idea?
Thank you,
Josep Maria
Hi @Josep Maria Pinyol ,
this usually means that there is an intermediate certificate missing from the certificate you're trying to import into the keystore. Can you find in your Gandi interface something like a "full chain" or "intermediate" certificate ? This is what you should then import into the keystore.
Let me know if this helps,
--Alexis
Ok, finally I can import my certificate using these steps:
1. Import root certificate:
keytool -import -alias root -trustcacerts -file USERTrustRSACertificationAuthority.crt
2. Import intermediate certificate:
keytool -import -alias intermediate -trustcacerts -file GandiStandardSSLCA2.pem
3. And finally
keytool -import -alias tomcat -file <YOUR_CERTIFICATE.crt>
And works fine.
Thank you @Alexis Robert
