from time to time our Easy-Mind plugin instance does not scale correctly maps it creates.
part of a map is out of the screen, therefore it is not showed correctly.
Is there any reason of this behaviour?
Thanks in advance for answer.
Hi Marcin,
thank you for your feedback.
Could you provide a EasyMind map which is shown incorrectly to me? You can send it to my e-mail address if you don't wanna share it with others. Thank you.
Please, could you provide the EasyMind version and the Confluence version as well? Thank you.
Tomas
Hello Marcin,
thank you for your message. Could you send the screenshot to info@morosystems.cz please? Thank you.
Please send me the source file of EasyMind map as well. You can find it in the attachments of the page, where the map is located. The file ends with .json. Thank you.
I am looking forward to your message,
Tomas
Hello Tomas,
Here are the versions of confluence and your plugin that I'm using:
Atlassian Confluence 5.4.3
EasyMind 1.4.10
As for the map I do not know how to send it to you, so I made a screen shot of an issue and send it via email,as soon as You will provide ma an address.
Marcin
