Sign up Log in
Problem with stylesheet in Confluence
DanielG
October 16, 2013
I made this stylesheet in my Confluence:
span#title-text.with-breadcrumbs {
color:transparent; background-image: url('URL IMAGE'); background-repeat: no-repeat; display: block; height: 60px; }
Image is showing OK in Dashboard :
But when I go to space, it's NOT ok...
I don't want to show logo in space, but it's the same class (CSS) in Dashboard. It's possible to create a new class to only show logo in Dashboard?
Can anybody help me?
Sean Curtis
October 17, 2013
Change your selector from...
to this...
body.dashboard #title-text {
There's no need for the with-breadcrumbs class addition. Basically just find something different between the pages which you can use to differentiate the style.
DanielG
October 18, 2013
You got the reason! Thanks Sean!
Best regards,
Dani
Steffen Heller
October 17, 2013
Just a general hint:
You must compare the two occurances of that image (in dashboard and space) and try to find differences in the html code around the image. This is not possible in confluence directly. You will need a tool like Firebug for this. If there are differences you can try to make use of them and define different CSS, one with "display: none" and one without.
Daniel Jonsson
Try this:
a[href="/homepage.action"] img {
/*your style here*/
DanielG
October 16, 2013
I don't understand your answer. I want to 'hide' logo in tittle space, but SHOW in my Dashboard... I put try this:
color:transparent;
display: block;
height: 60px;
But don't work!
