We want to convert a Trac wiki (with > 3.600 pages) to Confluence by using the UWC. One of the problems we have is that the Trac wiki users have used the Include macro in Trac. I have tried to adapt the Trac properties so that the Include macro is translated to the include-page macro in Confluence. I have tried the following line:
Trac.0770-include_links.java-regex-tokenizer=\[\[Include\(([^\]]+)\)\]\]{replace-with}{include:$1}
As a result I get for the following simple source page:
Here another include: [[Include(a/a-1)]]
The following page in Confluence:
<p>Here another include: <ac:link><ri:page ri:content-title="a-1)" /></ac:link></p>
Has anyone any idea what is going wrong here? Is there such a thing as issue tracker for UWC? I did not find anything usefull here: https://bitbucket.org/appfusions/universal-wiki-converter
Here comes the solution to my own question:
So here is the correct rule:
Trac.0655-include_links.java-regex-tokenizer=\[\[Include\(([^\)]+)\)\]\]{replace-with}{include:$1} Trac.0660-doublebracket-links.java-regex=\[{2}([^\]]+)\]{2}{replace-with}[$1]
So first, in the first line, the group was defined as ([^)]+), which means: match everything that is not a closing parantheses (not: bracket), and take that as the URL.
Second, define the rule before the doublebracket-links rule, so it can be replaced before.
The solution is not yet complete, because hierarchical page names ( like Include(a/a-1) ) should be replaced by the leaf of the hierarchy (here: a-1), so I have to adapt the regular expression, that I find the last title in the hierarchy.
See my question on stackoverflow to the problem of a regexpression that replaces the wiki title.
