Hi
I am looking at trying to setup a new confluence install. I am looking at having something like
Spaces
Wiki
Internal
External
Clients
Auditors
The thinking being that the last 4 spaces are read only spaces made up of pages from the Wiki which have specific tags assigned to it.
I was hoping to use some pluggin to do this, but the publish plugin you need 1 draft for each space you want to publish.
Any one else setup like this ?
Alex
Hi Alex,
From my understanding, it seems that you want to put certain content on other space to be displayed on other read only space. Would Include page Macro help in this case?
Cheers.
On a limited scope. the include would help, but say you had 100 - 1000 pages.
Every time you create a page in Wiki you would have to create the include pagas in the other spaces. not a very good work flow.
let me expand on my descriptio
spacepagelabels
wikiaExternal, Internal
bInternal, clients
So when I published out of wiki. I could easily (key word) select all the pages with the label External and copy those pages into space External. And similiarly do the same for Clients
I would end up with a copy of page A in External and a copy of page B in the clients space. Such that all the link referenced only the published works spaces.
The publish plugin looked good, but doesn't handle 1:N associations
Alex
Been playing around with this some more.
Maybe a slightly different approach is what needed.
How do I easily publish pages from my main space to another space, but where it only selects pages with a specific tag !
I don't want to click on lots of pages
Hallo Alex
Keep an eye on the Scroll Version plugin under development by K15t Software:
https://marketplace.atlassian.com/plugins/com.k15t.scroll.scroll-versions
It's currently in beta. It will have exactly the functionality you're looking for.
The Ad Hoc Canvas plugin from Comalatech may also be useful:
https://marketplace.atlassian.com/plugins/com.comalatech.adhoccanvas
Cheers
Sarah
Hmm
ad hoc canvas. looks okay, but you can't place a page in multiple and does it allow me to export /copy pages in a container to another space.. I need to be able to do that so I can limit peoples access.
A requirement (not really state before) was to limit access to pages by group permissions.
I know you can assign restictions to page. but that a pain to manually have to go in and make the changes - to easy to mess up. So apply permissions to a space seem like the easy way to go. So the need to export pages from the main space to a defined one is a must.
K scrolls ... I will have to have a look. But I couldn't find any documentation and like you said its a beta.. and thet are charging for it ...
when I get some free time i will have to download and install to try it out.... Which means i am going to have to get a test confluence setup !
okay thanks
I have a brief look through looks okay. But :) in my example
one page needs to be published in Clients and External and Internal (think wiki as the source space. Clients and External and Internal).
So not different versions, the same version.
The more i look at these the more I am thinking that the publish plugin need a little bit of work to limit it to publishing specific pages defined by their tag and I would have what I need :)
So back to my example. I can presume I can use different versions (Scrolls concept) to represent each of the different spaces. But it looks like it keeps a different copy of the page for each version ... which is not what I need
The Scroll Versions documentation is here:
http://demo.scrollwiki.com/display/VSN/Home
Still a draft! An upcoming version of the plugin will support conditional publishing, and publishing of selected pages to an existing space.
The K15t guys will be delighted to have your feedback.
