Sign up Log in
Question regarding Caching in Confluence
Chris
September 14, 2022
Hello!
I´ve got a question regarding our cache overview in Confluence.
There are some high values exceeding the max. entries, f.e.:
Embedded Crowd Group Object Child Memberships 189% - 1897/1000
Embedded Crowd Group Object Parent Memberships 189% 1890/1000
Content Bodies 123% - 12352/10000
Embedded Crowd Internal Group 116% - 17537/10000
These values have some performance impact i guess, as the system has to outsource on disk.
Any information on this issue would be very welcome.
Kind regards
Chris
Fabio Racobaldo _Herzum_
September 15, 2022
Hi @Chris ,
you can change cache values at your convenience in order to improve your instance performances. Please take a look to the following article https://confluence.atlassian.com/doc/cache-statistics-150472.html
Hope this helps,
Fabio
Chris
September 15, 2022
Hi Fabio!
Thank you for your quick response.
I know this overview, but it does not tell you the recommended maximum values.
Is it possible (does it make sense) to raise it to 2000?
Kind regards
Chris
September 15, 2022
Hi @Chris ,
my suggestion is to raise it to 2000.
Fabio
